This configuration example shows how to configure Fabric Attach (FA) proxy controlling bridge (CB) Extended Edge Switching This command is available on all Universal switches supported in this document. Ring CB peers to receive and approve VLAN/NSI mappings from FA clients connected to BPEs.
Slot-1 CB1-465.27 # show fabric attach assignments Fabric Attach Mode: Proxy Port VLAN VLAN Name Type ISID/NSI Status ------- ---- -------------------------------- ------- -------- -------- 143:6 505 SYS_VLAN_0505 Dynamic 5050 Active 143:6 707 SYS_VLAN_0707 Dynamic 70707 Active 143:6 4004 SYS_VLAN_4004 Dynamic 41414 Active
Slot-1 CB1-465.27 # show fabric attach elements
Mgmt Auto
System Id Port Type VLAN Tag Provision
00-04-96-9c-d4-5a-00-01-00-12 1:26 Server (No Auth) 1000 Mix Disabled
00-04-96-9a-8d-45-00-01-00-2f 1:27 Proxy (No Auth) 1000 Mix Disabled
00-04-96-9a-8d-45-00-8f-00-19 1:28 Proxy (No Auth) 1000 Mix Disabled
00-04-96-98-a9-1a-00-01-00-11 143:6 Switch 1000 Mix Disabled
* (pacman debug) Slot-1 VPEX CB1-465.28 #
* (pacman debug) Slot-1 VPEX CB1-465.28 # show fabric attach assignments
Slot-1 CB1-465.29 # show lldp ports 143:6 neighbors detailed
LLDP Port 143:6 detected 1 neighbor
Neighbor: 00:04:96:98:A9:1A/17, age 20 seconds
- Chassis ID type: MAC address (4)
Chassis ID : 00:04:96:98:A9:1A
- Port ID type: ifName (5)
Port ID : "17"
- Time To Live: 120 seconds
- System Name: "FAClient-switch_model"
- System Description: "ExtremeXOS (switch_model) version 30.4.0.524 30.\
4.0.524 by release-manager on Fri Oct 25 15:01:31\
EDT 2019"
- Avaya/Extreme Fabric Attach element
Element Type : 8
State : 0
Management Vlan: 1000
SystemId : 00:04:96:98:a9:1a
Link Info : 00-01-00-11
- Extreme Fabric Attach NSI(I-SID)/VLAN map
Status VlanID NSI(I-SID)
1 505 5050
1 707 70707
1 4004 41414
Slot-1 CB2-670.25 # show fabric attach assignments Fabric Attach Mode: Proxy Port VLAN VLAN Name Type ISID/NSI Status ------- ---- -------------------------------- ------- -------- -------- 143:6 505 SYS_VLAN_0505 Dynamic 5050 Active 143:6 707 SYS_VLAN_0707 Dynamic 70707 Active 143:6 4004 SYS_VLAN_4004 Dynamic 41414 Active
Slot-1 CB2-670.25 # show fabric attach elements
Mgmt Auto
00-11-88-fe-f3-66-00-7b-00-19 1:5 Proxy (No Auth) 1000 Mix Disabled
00-04-96-9c-d4-5a-00-01-00-05 1:24 Server (No Auth) 1000 Mix Disabled
00-04-96-99-9e-31-00-01-00-33 1:33 Switch 1000 Mix Disabled
00-11-88-fe-f3-66-00-01-00-1b 1:47 Proxy (No Auth) 1000 Mix Disabled
Slot-1 CB2-670.26 # show lldp ports 143:6 neighbors detailed
Neighbor: 00:04:96:98:A9:1A/17, age 22 seconds
Port ID : "17"
EDT 2019"
Element Type : 8
State : 0
2 505 5050
2 707 70707
2 4004 41414
